Ignition key not turning enough to engage the starter |
moggy |
Jul 12 2006, 11:49 AM
Member Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
I recently had a problem where the car would not start. I isolated it to the starter switch which as when I shorted the relevant wires out at the starter switch the starter would engage and the car swould start. I've now replaced that electrical part at the end of the starter switch mechanism but it has made no difference. If I take the electrical bit out and start it with a screwdriver it starts no problem. It appears that the key does not turn enough to engage the starter. Has anyone else come across this? I can't see anyway to take the tumbler and whole mechanism apart, so am I screwed??? do I have to buy the whole switch/lock/tumbler mechanism or am I barking up the worng tree (IMG:style_emoticons/default/sad.gif)
ptravnic |
Jul 12 2006, 12:01 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Look up the tech article on the pelicanparts.com site. Pics and description of the replacement. I've been through a couple of the plastic pieces. It's a common failure and fairly easy fix.
-pt |
moggy |
Jul 12 2006, 01:00 PM
Look up the tech article on the pelicanparts.com site. Pics and description of the replacement. I've been through a couple of the plastic pieces. It's a common failure and fairly easy fix. -pt Thanks for your response but as I said in my post I've already replaced the plastic part and still no go (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:09 PM |
