> Which bushings: PolyGraph, Bronze, needle bearing,, or Delrin?
airsix
post Feb 28 2003, 12:09 PM
I have bees in my epiglotis
Ok guys, what suspension bushings/bearings should I be installing?
Options:
Poly Graphite (soft/hard)
Delrin
Bronze
Needle bearing
Most importantly what kind of life can one expect from each of these options before things start getting sloppy from wear? Since the car is dual purpose I am interested in ALL the pros & cons of each.
Car: (to give an indication of my personality type)
Dual purpose currently set up with:
21mm torsion bars
19mm adjustable front swaybar
Koni sport yellows on medium
180# rear springs
911 vented A's on all 4 corners
225's on 7" front and 245's on 8" in rear
EFI turbo 1.7 to be replaced with 2.7 six (once it's finished)
-Ben
Bleyseng
post Feb 28 2003, 04:18 PM
Aircooled Baby!
If cost is a factor stay with the plastic bushings, they are pretty cheap. Bronze and Mueller bearings cost $$$.
With the plastic bearings make sure you get the supplied grease!
Geoff
- Lo-Fi Version Time is now: 29th April 2025 - 06:11 PM
