> How do you replace the two shift coupler bushings?, ...just drive the shaft out, is there a pin on it?
neo914-6
post Jul 20 2006, 03:15 AM
neo life
can't see what's holding it in...
maf914
post Jul 20 2006, 07:03 AM
Not a Guru!
If you have a bench vise that's the way to go. My method was a little more basic.
I removed the shift rod with coupler attached and sprayed it with penetrating oil. I took a block of wood (actually a piece of landscaping timber) and drilled a hole a little larger in diameter than the pin in the coupler and deeper tham the length of the pin. I placed the coupler on this block with the pin centered on the hole and gently tapped the pin into the hole using a hammer and punch. Gently, because as stated above the coupler is somewhat fragile. It looks like cast aluminum or pot metal and is probably brittle. In my case the pin came out with relative little force from the hammer. (IMG:style_emoticons/default/smash.gif)
Remove the old bushings and replace with new from the inside of the coupler. Reposition on the shift rod and tap the pin back in. (IMG:style_emoticons/default/smash.gif)
Be patient and don't force it. Replacement couplers aren't cheap! (IMG:style_emoticons/default/thumb3d.gif)
neo914-6   How do you replace the two shift coupler bushings?   Jul 20 2006, 03:15 AM
jr91472   This first thing is to remove the shift rod from t...   Jul 20 2006, 06:45 AM
Joe Sharp   Felix: I take a piece of something like 1/8 plate ...   Jul 20 2006, 07:01 AM
maf914   If you have a bench vise that's the way to go....   Jul 20 2006, 07:03 AM
solex   I just did this and had a hell of a time trying to...   Jul 20 2006, 07:28 AM
Aaron Cox   i did a quickee write up on this... PITA....   Jul 20 2006, 07:41 AM
URY914   A few tips: A little heat should help things along...   Jul 20 2006, 08:02 AM
neo914-6   All Good advice, I used my small vise and the pin ...   Jul 21 2006, 01:53 AM
neo914-6   3. I then pulled the pin out with pliers and a rag...   Jul 21 2006, 01:55 AM
neo914-6   5. To get the second bushing in I used the pin and...   Jul 21 2006, 01:56 AM
McMark   Nice writeup Felix. :D :thumbsup:   Jul 21 2006, 02:17 AM
jr91472   YO Admins!! Can this go in the Classics? ...   Jul 21 2006, 07:46 AM
elwood-914   I was just looking at my bushing kit and wondering...   Jul 21 2006, 07:55 AM
jonwatts   I rarely think to take the time to document when I...   Jul 21 2006, 08:40 AM
neo914-6
- Lo-Fi Version Time is now: 21st December 2024 - 10:57 PM
