No horn, I changed the switches in the column |
Stieve |
Jul 21 2006, 11:47 AM
Senior Member Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 |
I bought a set of 924 switches, and am almost done with the converesion, except for hooking the brown to ground and the hot to the pump then grounding the pump. I couldn't refuse adding the trun signal, because mine was disfunctional, ok it was broke. I added the Dino wheel, replaced the crush sleeve, and hooked up yhe button, and now nothing.
Stieve |
Jul 21 2006, 01:55 PM
I have a Dino wheel, so no problem with the wire, all self contained. If I wull off the wheel do I ground the brass horn tab to the steering shaft or just depess it to check?
Lo-Fi Version | Time is now: 18th October 2024 - 12:15 AM |
