Got my new engine, this is fun |
michel richard |
Jul 28 2006, 07:03 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
I know this is just an engine, and that it don't look like much, but it's a 6 cylinder. Specifications are as follows:
Cylinders: 6 Stroke: 66 mm (short stroke) Bore: 89 mm Crank: 2.0 / 2.2 counterwheigted std/std Case: Late 7R Pistons JE pistons, 10.5/1 nominal compression ignition: Electromotive HPV1, twin plug Camshafts: GE80 Fuel: PMO 40 MM carburetors Venturies: 36 mm Jetting: details to follow Ports: I 36 mm / E 36 mm Valves: Standard Valve springs EBS sport springs Expected redline: 8,000 Expected HP: 225 - 250 hp And here a re a few pictures. I am having a close ratio gearbox built. As soon as that is done (early next week) I will bolt the assembly into the car. Cheers. Attached image(s) |
michel richard |
Jul 28 2006, 07:05 PM
From the side.
Ignition wires still need to be sorted out. Attached image(s) |
Lo-Fi Version | Time is now: 8th January 2025 - 03:54 PM |
