siverson |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California ![]() ![]() ![]() |
Hi,
Thanks for the advice on the seatbelts. A pair of black Schroth Profi III 5-point belts arrived yesterday (ordered Friday!) and while kinda pricy, it was a simple purchase and they appear to be very high quality. http://www.subesports.com/products/?cartID...roth&prodID=587 Now, where to mount... I've researched this a bit, but have read somewhat conflicting statements. The Schroth manual specifically says not to mount the belts on a seat with a headrest, like the 914, but that appears to be what everyone does. Hmmm... Anyways, before I start drilling holes, I thought I'd run this by you guys to see what you think. The red dots denote where I'll mount the shoulder eye bolts (with backing plate) and the red line is where I'll cut (another) hole for the sub strap. Note I lowered the drivers floor about 1", that's why the seat is already cut up a bit. I'm 6'6", so those eye bolts would be parallel to my shoulders (0 degrees), and the sub-strap would be straight down. The lap belts will go to stock mounting points. (IMG:http://www.streamload.com/steve/914_update_10-14-2003/seatbelts_shoulder.JPG) (IMG:http://www.streamload.com/steve/914_update_10-14-2003/seatbelt_crotch.JPG) Whaddya think? (IMG:style_emoticons/default/confused24.gif) Another random question: I'm hoping my car passes tech inspection when complete (!)... Do I -really- need to keep all these fugly tags on the new seatbelts. Each belt (10 total for the car) has 2 tags with the date and warning, that Schroth emphasizes must stay on the belt. Does tech inspection care about the date (2008) that these belts "expire"? Also, for the really curious, this is how I ended up resolving my old brake line issue (http://www.914world.com/bbs2/index.php?act=ST&f=2&t=4730&hl=siverson). Much better, huh? (IMG:style_emoticons/default/smash.gif) (IMG:http://www.streamload.com/steve/914_update_10-14-2003/rear_brake_line_fitted.JPG) (IMG:style_emoticons/default/mueba.gif) -Steve |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,557 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
Ideally you should have a race seat with harness slots, to keep the belts positioned correctly w/o a chance to slip off. The GCR's of most of the sanctioning bodies will specify the allowable angles for the shoulder belts and sub belt. You also are not supposed to have more than one belt connected to the same mount point (which your pic wouldn't, but I thought I'd throw that in anyhow). The more serious groups will tech your belt expire dates too. If you are just planning to to autox then you can "get away" with a lot more in tech inspection, in fact the PCA autox techs I have encountered (in years past) essentially just gave the car a 30 second walkaround and eyeballed the battery mount and wheel bearing freeplay. DE's typically have no tech inspection at all, so it's up to you...
Lo-Fi Version | Time is now: 1st July 2024 - 01:47 AM |
