How to re-attach in cabin rear view mirror |
lmcchesney |
Jul 31 2006, 07:12 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
My stock rear view mirror came off yesterday. It had previously been glued to the mounting base. There is a small silver plate which the mirror has a mounting screw to attach the mirror to the base. The small silver base came out of the mount. Is epoxy glue, which is what I believe was used, the only method of attachement?
What has been found to be a reliable attachement method? Thanks, Larry |
Midtowner |
Jul 31 2006, 03:49 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
I recommend a search using the words "mirror" on this site. There is a thread strongly against using epoxy due to different expansion rates between the glue and glass. Net result is usually a round-ish crack in the windshield. I successfully attached by masking then sanding the glass surface using 600 grit, thoroughly cleaning the mating surfaces, and using the mirror attachment glue kit from FLAPS. Helps to allow a few days to dry before attaching the mirror to the base. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 6th January 2025 - 04:42 PM |
