Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
What is the best method for cleaning all of the electrical contacts??
The solderless terminals could use some cleaning as well as all of the fuse contact posts. |
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Diapers? If you look around electronics stores, you may find a small tub of dielectric grease, apply it to both sides of closing connectors after you clean them with Blue Shower, or sameish, and use a small brass brush (fuzzy one works best) on hard to clean ones. (brass is softer than steel... yaya) A bore brush works great, they make tiny ones, good for the deep connectors. (not a steel brush) The grease will save you from going back in there ever again, use sparingly.. Dab'l dooya, Mate! M |
Lo-Fi Version | Time is now: 1st July 2024 - 03:03 AM |
