Original 914/6 engine management, A couple of questions |
michel richard |
Aug 2 2006, 07:55 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Please let me know if I have this right:
1) Original /6 cars came with Porsche's electronic ignition module of the time i.e. the BZK module, as opposed to only super-basic Kettering (sp?) points. 2) Fuel was carbs, of course, but there was an additional cranking enrichment which necessitated a thermotime switch, a "dashpot" on the throttle somewhere and perhaps a couple of other electrical widgets. I'm trying to make sense of the engine wiring harness that I have, which is from a /6. Thank you. Michel |
DonTraver |
Aug 2 2006, 08:59 AM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
The cold start enrichment was a disaster waiting to happen. It was two 2-3mm pipes with hole drilled in them that dumped raw gas into the intakes of each velocity stack. The pipes were mounted in the orginal air filter housing, controled by a valve over above the #3 cylinder. Didn't work very well, and was known to start engine fires. I still have the system, but it was taken off shortly after I bought my 6 from my step dad. Without it, I have to give them engine a couple of minutes to get the cylinder temps up before driving off.
Later, Don |
Lo-Fi Version | Time is now: 9th January 2025 - 03:21 PM |
