Original 914/6 engine management, A couple of questions |
michel richard |
Aug 2 2006, 07:55 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Please let me know if I have this right:
1) Original /6 cars came with Porsche's electronic ignition module of the time i.e. the BZK module, as opposed to only super-basic Kettering (sp?) points. 2) Fuel was carbs, of course, but there was an additional cranking enrichment which necessitated a thermotime switch, a "dashpot" on the throttle somewhere and perhaps a couple of other electrical widgets. I'm trying to make sense of the engine wiring harness that I have, which is from a /6. Thank you. Michel |
michel richard |
Aug 2 2006, 09:29 AM
Don,
You mean the system was designed to dump fuel down the carbs even after cranking ? Yikes. Thanks for the info, gentlemen, this will give me more confidence as I wire my engine compartment. Cheers, Michel |
Cap'n Krusty |
Aug 2 2006, 10:48 AM
Don, You mean the system was designed to dump fuel down the carbs even after cranking ? Yikes. Thanks for the info, gentlemen, this will give me more confidence as I wire my engine compartment. Cheers, Michel That's NOT true. It sprays ONLY while cranking, and then only for a limited amount of time(determined by the TTS). The Cap'n |
Lo-Fi Version | Time is now: 9th January 2025 - 03:17 PM |
