Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Our electric bills are killing us.
It doesn't help that our house is ON 24 hours since we have nurses in the house taking care of Hunter, and they of course want to watch TV. Background info... Our house is 5,000 sq. feet, masonry, with tile roof, and reflective film on the main windows. It was built well, and insulated well (in the walls and with blown-in insulation in the attics). We have gas water heaters and cook with gas. Our house has three ACs (due to size) and for our son's special needs. We also have 4 refrigerators (one huge main fridge, one regular fridge in the pantry for sodas and pizza and misc. crap, a wine fridge, and a mini-fridge for Hunter's medications (in his bathroom) This is what we've done over the past year to help curb the bills... 1. Main House AC is at 80 all the time 2. Hunter's AC is at 78 full-time 3. Third A/C (my bedroom) is at 80 in the daytime and 74 at night (when we sleep) 4. I replaced about 24 of our ceiling can lights with compact flourescent bulbs 5. I replaced our two nightstand bulbs with compact flourescents 6. I replaced the six bulbs in Hunter's bathrrom with compact flourescents. 7. Pool pump runs only 6 hours per day to circulate chlorine 8. Spa pump runs 2 hours per day 9. Front yard lights (low voltage) are on for about 2.5 hours. 10. A/C filters are changed regularly 11. Rear yard lights are not on at all 12. Only one light is on in the kitchen at night (for the nurses) 13. The rest of the house has "nightlights" which are LED nightlights 14. Adjusted the fridges to medium cooling setting (vs. max cool) 15. Ceiling fans run on slow to circulate air. All this has been in place about a year with negligible results. Our most recent bill... $1,183.00 WTF! (IMG:style_emoticons/default/blink.gif) Our bill at this time last year (before changes wer made) was around $800.00. That being said... I do know that the utility rates have gone up 22% in a year. So today, we decided to add to the list... 1. Keep the blinds closed in our masterbedroom permanently (they are light-blocking, foil-lined horizontal blinds) 2. Disconnected the mini wine fridge 3. Turn off the three PCs and monitors in the house when not being used 4. Reduce the number of loads of laundry by 25% per week. 5. Search for a few more bulbs to swap out with compact flourescent What else can we do, besides move? I don't want to live in a cave. I want to be able to enjoy the house and watch TV and have it comfortable inside. It's kind of hard when it's 95 degrees out and 90% humidity! Your suggestions of things to look for, adjust, turn off, is appreciated Thanks! |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
You can't use an evaporative cooler in a humid environment. They use water to cool the air passing through a wet filter. In florida all you have to do is turn on a fan to get the same effect. They are for dry climates and work great south and west from Colorado.
I've been told that leaving an AC'd area at a high temp and then cranking the AC down to cool (like the night-time scenario you described) actually uses more energy. I can't say that that's true for certain, but I just leave my ac at 75 all day and then kick it down to 73 at 10:00 p.m. I never checked for the actual difference in cost, but I know if I leave the ac at say 78 during the day when I'm at work and then set it at 74 when I get home in the late afternoon, it works and works and works and works to get the temp down. On a hot day it can take hours to get from 78 to 73. Might be something to experiment with. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:27 PM |
