Stripping a Teener, How much did you pay? |
So.Cal.914 |
Aug 4 2006, 03:32 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Called yesterday and they want $1300.00 to soda blast my tub. That to me
seems high. I know it was many years ago but we paid $200.00 for a 55 chevy. Could you let me know what you have paid lately. Thanks. |
goodporsche |
Aug 4 2006, 04:27 PM
Newbie Group: Members Posts: 5 Joined: 12-June 06 From: New Jersey Member No.: 6,206 |
I don't know what it costs to blast a chassis but I am getting mine dip striped and it will cost $1600. That will remove all the paint, seam sealer, etc. Then it will be dipped to remove all the rust. The only down side is the heater hose that runs through the chassis is destroyed and cannot be replaced (or removed) without removing the outer frame member, not a problem for me because I will be using an oil cooler for my heat setup.
G e o r g e |
Aug 4 2006, 04:35 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
I don't know what it costs to blast a chassis but I am getting mine dip striped and it will cost $1600. That will remove all the paint, seam sealer, etc. Then it will be dipped to remove all the rust. The only down side is the heater hose that runs through the chassis is destroyed and cannot be replaced (or removed) without removing the outer frame member, not a problem for me because I will be using an oil cooler for my heat setup. will the first dip strip the under coating? (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 11:40 AM |
