jk76.914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States ![]() |
![]() Been pokin around the internet trying to learn as much as I could about D-Jet. Well, I came across an article on the original Bendix Electrojector EFI (the real FIRST EFI), and I thought some of you guys would enjoy it as much as I did.... Apparently, Chrysler made a total of about 35 cars- Chrysler, deSoto, Plymouth- with the $400 Elecrojector option. They had a lot of problems with it. Today, it is thought that it was mainly due to the poor reliability of the electronic components- especially the waxed-paper bodied capacitors- that led to its problems and demise. Anyway, all but a couple were converted to dual 4-barrel carbs at Chrysler's expense. Then they licensed the technology to Bosch, who improved upon it and rolled out our beloved D-Jet. The article is at http://www.ch300imp.com/bendix_us.htm Another article I found described the workings in slightly more detail at- http://216.120.237.3/cars/desoto/electrojector.html It says- Here's how the Bendix system was supposed to work: Electronically controlled and electrically actuated, the "Electrojector" had a transistor-equipped brain or modulator, about 5 inches in size. The brain took a timed electrical signal from the ignition distributor. It sensed, through tiny electronic transmitting devices located at key points on the engine, the engine's temperature, throttle position, manifold pressure and even the altitude (or density) of the air being sucked into the cylinders. The modulator integrated all of the information received and instantly translated this data into a control signal that actuated the injectors," according to an article in Bendixline, a company newsletter, dated Sept. 28, 1956. Pretty cool. It even "took a timed signal from the ignition distributor". Here are some pictures I downloaded from one of the links- Notice all the similarities- the brain hasn't changed much. Same with the fuel rails and the cross-over fuel line- yup, seen that somewhere before. Mother! look at those Electrojectors! Don't get your Timex too close when it's idling! Couldn't locate the MPS. Maybe one of you guys can in the linked photos. Maybe it's forward compatible! Maybe there's a case of them somewhere in some warehouse! ![]() ![]() This is on a 1958 deSoto Adventurer convertible. It's owned by a Mr. Tom White in Massachusetts. It sure is a beauty. |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Wow, that's cool. I knew 50's chevies had FI available, but I believe it was mostly mechanical (if not completely). EFI in the 50s.. amazing!
Lo-Fi Version | Time is now: 25th June 2024 - 08:11 PM |
