Help - clutch stuck / rusted to flywheel or output shaft.. |
matt_o_70 |
Aug 6 2006, 07:13 PM
Newbie Group: Members Posts: 33 Joined: 6-July 04 From: rochester NY Member No.: 2,312 |
So the first week of july I cut the bottom of my foot real bad and have been un able to drive a standard since - I just attempted to drive the 914 and the clutch disk is stuck engaged. I have tried to bump it loose by starting it in gear and hitting the brakes etc with clutch in . No luck yet. It is quite stuck
Anyone else ever have this happen - how did you get it unstuck? The PO had this problem when storing the car for winter so he parked it with a stick against the clucth to keep it slightly disengaged. looking for some suggestions. |
jd74914 |
Aug 7 2006, 07:57 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I've seen this . . . the solution on my car was that I had to drop the engine and pull everything apart with the engine and tranny split.
mihai914 |
Aug 7 2006, 09:59 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
I've seen this . . . the solution on my car was that I had to drop the engine and pull everything apart with the engine and tranny split. There is enough flex in the motor mounts to drop the transmission only by itself, you do need to support the motor at the rear lower "bump" in the case near the flywheel. I think someone did a write-up on dropping the transmission only. |
Lo-Fi Version | Time is now: 24th June 2024 - 11:43 PM |
