> Which bushings: PolyGraph, Bronze, needle bearing,, or Delrin?
airsix
post Feb 28 2003, 12:09 PM
I have bees in my epiglotis
Ok guys, what suspension bushings/bearings should I be installing?
Options:
Poly Graphite (soft/hard)
Delrin
Bronze
Needle bearing
Most importantly what kind of life can one expect from each of these options before things start getting sloppy from wear? Since the car is dual purpose I am interested in ALL the pros & cons of each.
Car: (to give an indication of my personality type)
Dual purpose currently set up with:
21mm torsion bars
19mm adjustable front swaybar
Koni sport yellows on medium
180# rear springs
911 vented A's on all 4 corners
225's on 7" front and 245's on 8" in rear
EFI turbo 1.7 to be replaced with 2.7 six (once it's finished)
-Ben
Dave_Darling
post Mar 3 2003, 04:29 PM
914 Idiot
Step 1--Take 'em all apart.
Step 2--File and hone and sand to fit. They all gotta fit proper.
Step 3--Use the "gorilla snot" grease that Weltmeister supplies. (Half grease, half velcro, an alllllll nasty!)
JP has been figuring out the "file and hone and sand to fit" routine for a while. I think he has some ideas for you.
Note that, with the bearings, there is zero "stiction" like you are noticing in your current setup.
--DD
- Lo-Fi Version Time is now: 29th April 2025 - 06:06 PM
