> Front main seal and..., disty drive gear question.
LowGT
post Aug 13 2006, 11:48 PM
1.8 and Proud!
So I spent most the day cleaning and replacing every seal in the engine. Only ones left are the rear main (have to get the engine off the stand for that) and the front main.
Can the front main be replaced without splitting the case? If so, do I just need to remove that one bolt and pull the fan bracket off to get acess to it?
Secondly, I flipped the motor on the stand and the disty was out. So my disty drive gear fell out and onto the floor. How can I get it back in correctly? **Hopes there is only one way it will go in.**
Dan
Dave_Darling
post Aug 16 2006, 02:53 PM
914 Idiot
So will three big fender washers.
How? Easy: Install the three fan mounting bolts into the hub, and run them down far enough that their ends trap (very large!) tough fender washers between the bolt and the case. This is to protect the case from damage, BTW--very important! Then turn each bolt 1/2 turn at a time, and the hub will pop right off! Make sure to have something under it to catch the Woodruff key, because it likes to bounce and is a b--ch to find once it does.
--DD
- Lo-Fi Version Time is now: 27th December 2024 - 10:54 AM
