jsf322 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 1-December 05 From: Baldwin, New York Member No.: 5,220 ![]() |
I just checked my MPS because my car is running rich, burns a lot of fuel, and idles very poorly especially when warm. The CHT was bad and I replaced that. IT improved the stalling I had before replacing it, but the car is still rich and idles very unpredictably. I put 15mm Hg on the MPS and it lost about 1/2 mm in the first minute and 4-5mm within 5 minutes. Would that be considered a bad MPS. If so does anyone have experinece with rebuilt units from AA or Preformance Products. AA is about $40 cheaper. Thanks for any input.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
You should have about 15hg at idle with a steady needle on the gauge.
if you don't check your compression with a tester check for vacuum leaks check for the timing being off with a timing lite check the valve adjustment! (IMG:style_emoticons/default/sad.gif) the engine must first be in a good state of tune to start to even figure out what is going on with the FI. Then half the time after all the other issues are fixed the "FI problem" goes away. (IMG:style_emoticons/default/clap56.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:58 PM |
