jsf322 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 1-December 05 From: Baldwin, New York Member No.: 5,220 ![]() |
I just checked my MPS because my car is running rich, burns a lot of fuel, and idles very poorly especially when warm. The CHT was bad and I replaced that. IT improved the stalling I had before replacing it, but the car is still rich and idles very unpredictably. I put 15mm Hg on the MPS and it lost about 1/2 mm in the first minute and 4-5mm within 5 minutes. Would that be considered a bad MPS. If so does anyone have experinece with rebuilt units from AA or Preformance Products. AA is about $40 cheaper. Thanks for any input.
jsf322 |
okay here is some more information. The valves were adjusted about 500 miles ago as well as the timing checked and the dwell set. I tested the temp sensor at the throttle body and it gave the correct numbers. The CHT I replaced because the wire going into it was having issues and when it moved slightly the car would stall. Now it does not stall. When I first start the car it dies and will immediately restart and stay running. Sometimes if I try to move it right away it will pop back a little if I do not give it a lot of gas. after a minute or two of running there is no problem with that. There are times when it will idle rock steady, but if I push the pedal down at all when it is idling well it will immediately start to go up and down on idel from almost 0 to about 1000 rpm. When I pull up to a stop the car drops idle for a moment to almost a stall and catches and is okay but idle wanders. I can smell it running rich and it is only getting about 21-23 mpg. I will check the ECU and MPS to see if the numbers match but from what I know of the car they are original to the car. Th engine only has 44K original miles and not much was done to it over the years. I have replaced all of the vacuum lines and fuel lines except the ones in the tunnel because they were amazingly good. The fuel pressure is about 30-31 lb. The car has plenty of power when driving and no hesitation at any point in the full RPM range after idle.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
okay here is some more information. The valves were adjusted about 500 miles ago as well as the timing checked and the dwell set. I tested the temp sensor at the throttle body and it gave the correct numbers. The CHT I replaced because the wire going into it was having issues and when it moved slightly the car would stall. Now it does not stall. When I first start the car it dies and will immediately restart and stay running. Sometimes if I try to move it right away it will pop back a little if I do not give it a lot of gas. after a minute or two of running there is no problem with that. There are times when it will idle rock steady, but if I push the pedal down at all when it is idling well it will immediately start to go up and down on idel from almost 0 to about 1000 rpm. When I pull up to a stop the car drops idle for a moment to almost a stall and catches and is okay but idle wanders. I can smell it running rich and it is only getting about 21-23 mpg. I will check the ECU and MPS to see if the numbers match but from what I know of the car they are original to the car. Th engine only has 44K original miles and not much was done to it over the years. I have replaced all of the vacuum lines and fuel lines except the ones in the tunnel because they were amazingly good. The fuel pressure is about 30-31 lb. The car has plenty of power when driving and no hesitation at any point in the full RPM range after idle. 1. change out the points to a Crane optical points replacement. Electronic ignition is a big help. 2. Set the idle mix when the engine is hot, after 15 mins of driving, AAR valve is closed. Use a CO meter if you can get one, go to a shop etc.....or pull over after the car is hot and reset the idle ECU screw to where the engine idles good and reset the idle speed to 950. Do it a couple of times. The idle knob on the ECU should be close to the factory notch. It sounds like the idle mix is rich a bit. Make damn sure the vacuum hoses are setup correctly. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:53 PM |
