901 weak links and, my 901 is apart and I want to get it in proper order to handle a LOT o |
RXBeetle |
Aug 20 2006, 02:01 PM
Newbie Group: Members Posts: 3 Joined: 20-August 06 From: MI-USA Member No.: 6,699 |
First post, noob here! Hello all and thanks for letting me in on your fun.
I have a 74 Super Beetle.... ok you can all stop laughing now. (914 someday, but for now I like my Bug) I am in the process of upgrading from a stock VW trans and a 12A rotary engine to a turbo 13B (~300hp and 250ft/lb of torque) and a 901 transaxle. I am sending some engine parts out for nidriding and I would like to get in as many parts as I can while I am at it that may benifit from the treatment. I am aware of the first gears lack of support and was thinking that having the drive and pinion shaft nitrided to make them less prone to deflection (I will still be gentle, not a drag car). I am a little worried about the diff since it's only a 2 spider and a Quaife is not in the budget. I think nitriding the diff housing should help reduce flex and keep the pinion gears fully engaged. I will probably have the pinion gears done as well. Now I'll admit that this is the first trans I have had apart and I am not familiar with what is prone to failure and what is fine for these power levels. In the Type 1 world you always hear the welded keyed 3rd and 4th, super diff, heavy duty side cover, etc. So if any one has some good info on how to beef up a 901 that would be greeeeat PS anyone have a 901 nose cone from a 911 laying around??? PPS who ever had the red 914 out at the woodward dream cruise yesterday (IMG:style_emoticons/default/aktion035.gif) very nice, very clean, kick ass. Thanks! |
kdfoust |
Aug 20 2006, 02:35 PM
Senior Member Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
Nitriding is a surface treatment. You could think of it as being something akin to case hardening. It does produce a hard, wear resistant surface but nitriding won't change the deflection of the parts you are considering nitriding.
Good luck with your project. It sounds like fun! Regards, Kevin |
Lo-Fi Version | Time is now: 27th December 2024 - 12:43 PM |
