> 19mm master, no pedal feel
Brew
post Aug 20 2006, 05:39 PM
That's Captain Moron to you!
Did I miss something?
I changed out my old MC for a new 19mm per the Pelican article, and changed out my soft lines while I was at it. I've bled all 4 corners with a vacuum pump, but the pedal still goes to the floor. I cant get it to pump up at all, even depressing it multiple (~50) times.
Help?
Dr. Roger
post Aug 20 2006, 05:46 PM
A bat out of hell.
i wouldn't use the vacuum pump eventhough many do.
i use a buddies foot and my tubing wrench. never fails. =-)
Brew   19mm master   Aug 20 2006, 05:39 PM
Dr. Roger   i wouldn't use the vacuum pump eventhough many...   Aug 20 2006, 05:46 PM
bd1308   Got fluid in the resivour? I lost my brake fluid ...   Aug 20 2006, 05:48 PM
john rogers   It sounds like you have air. If you do not have a ...   Aug 20 2006, 05:51 PM
Borderline   i've never tried a vacuum system. I bought a ...   Aug 20 2006, 05:51 PM
Flycut   First thing with Brakes is pad adjustment, Fronts ...   Aug 20 2006, 06:05 PM
Dr. Roger   i should add.... when i was having issues trying ...   Aug 20 2006, 06:10 PM
Brew   Is it not neccessary to bench bleed the MC on thes...   Aug 20 2006, 06:11 PM
Joe Ricard   Yes bench bleeding the M/C is a good idea. I made...   Aug 20 2006, 06:46 PM
JPB   I just did this and this is the way to go. First,...   Aug 20 2006, 06:55 PM
Dr. Roger   "flycut" is right on also...... it does...   Aug 20 2006, 07:10 PM
Brew   Thanks all! I'll mess with it more tomorr...   Aug 20 2006, 08:14 PM
PRS914-6   Are you tightening the bleeder screw before the pe...   Aug 20 2006, 09:08 PM
So.Cal.914
- Lo-Fi Version Time is now: 28th December 2024 - 01:30 AM
