> 19mm master, no pedal feel
Brew
post Aug 20 2006, 05:39 PM
That's Captain Moron to you!
Did I miss something?
I changed out my old MC for a new 19mm per the Pelican article, and changed out my soft lines while I was at it. I've bled all 4 corners with a vacuum pump, but the pedal still goes to the floor. I cant get it to pump up at all, even depressing it multiple (~50) times.
Help?
PRS914-6
post Aug 20 2006, 09:08 PM
Excellence Magazine Project 914 3.6
Group: Retired Members
Are you tightening the bleeder screw before the peddle comes up? If not, the air just goes back and forth. Also, use smooth, slow strokes on the peddle. Lot's of people pump the hell out of the peddle and it just makes matters worse by aerating the fluid. After I get the system feeling good and I think I am done, I come back several hours later and bleed one more time. I always get a little more air out after things settle down.....
Brew   19mm master   Aug 20 2006, 05:39 PM
Dr. Roger   i wouldn't use the vacuum pump eventhough many...   Aug 20 2006, 05:46 PM
bd1308   Got fluid in the resivour? I lost my brake fluid ...   Aug 20 2006, 05:48 PM
john rogers   It sounds like you have air. If you do not have a ...   Aug 20 2006, 05:51 PM
Borderline   i've never tried a vacuum system. I bought a ...   Aug 20 2006, 05:51 PM
Flycut   First thing with Brakes is pad adjustment, Fronts ...   Aug 20 2006, 06:05 PM
Dr. Roger   i should add.... when i was having issues trying ...   Aug 20 2006, 06:10 PM
Brew   Is it not neccessary to bench bleed the MC on thes...   Aug 20 2006, 06:11 PM
Joe Ricard   Yes bench bleeding the M/C is a good idea. I made...   Aug 20 2006, 06:46 PM
JPB   I just did this and this is the way to go. First,...   Aug 20 2006, 06:55 PM
Dr. Roger   "flycut" is right on also...... it does...   Aug 20 2006, 07:10 PM
Brew   Thanks all! I'll mess with it more tomorr...   Aug 20 2006, 08:14 PM
PRS914-6   Are you tightening the bleeder screw before the pe...   Aug 20 2006, 09:08 PM
So.Cal.914
- Lo-Fi Version Time is now: 28th December 2024 - 01:42 AM
