> Brake Guru's....what brake rotor do I have?
nine14cats
post Aug 20 2006, 10:33 PM
Bill Pickering -- 914-6 GT aka....Leeloo
My track car has C4 calipers in the front (or at least uses C4 pads). I would like to confirm what rotors are on the car. As you can see from the picture the hub bolts to the rotor.
Anyone know what I have or how I can tell?
Thanks,
Bill P.
Jeroen
post Aug 21 2006, 07:04 PM
Region Association: Europe
QUOTE(Eric_Shea @ Aug 21 2006, 11:19 PM) *
Cars of that era could have a Turbo Look option and they would get everything; rotors and calipers.
yep, a turbo look model (through '89) would have turbo (930) suspension/brakes
but these are not 930 calipers, they are later (post '89) and AFAIK, those don't mix with 930 rotors
check this page for brake dimensions
http://www.pelicanparts.com/MotorCity/wmv/brakes.htm
930 rotors are 304mm dia and 32mm thick
964 rotors are 298mm dia and 28mm thick
so since you have (what appear to be) 964 calipers, those are most definately not 930 rotors...
I think your best bet would be to measure the rotor (dia, thickness and bolt patern/offset of the bell) and check with Coleman
(you only need the rotor, not a new bell)
- Lo-Fi Version Time is now: 4th January 2025 - 05:47 PM
