V8 guys...how do you set timing?, Can't see the timing mark... |
cobra94563 |
Aug 22 2006, 10:37 PM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
Is there a easier way? (IMG:style_emoticons/default/confused24.gif)
cobra94563 |
Aug 23 2006, 04:07 PM
Good idea there..
I was thinking I could attach a pointer lower on the pulley, remark the pulley and time on that. But if the flywheel is accessible, that too would be a good point. I agree on setting total timing... (IMG:style_emoticons/default/thumb3d.gif) I get away with 36 total on pump, but my compression is only about 10. |
byndbad914 |
Aug 23 2006, 04:36 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
I was thinking I could attach a pointer lower on the pulley, remark the pulley and time on that. But if the flywheel is accessible, that too would be a good point. fact is, once you have TDC on #1, any mark you make is arbitrarily TDC, so you could extend a pointer tab tacked onto the oil pan even to the balancer and paint a stripe. The issue there is the next part of the quote - total timing. Hard to hold the throttle open to 3K and time on your back under the car - unless you got some rubber arms I should know about (IMG:style_emoticons/default/biggrin.gif) The opening on the trans is right on top behind the distributor, so can't get much better for being able to stand in one spot. QUOTE I agree on setting total timing... (IMG:style_emoticons/default/thumb3d.gif) I get away with 36 total on pump, but my compression is only about 10. yeah, you should be fine. I am 11.13:1 with long rods, so I can't get away with it. I was surprised I got that far on a SBC, but timing is pretty cylinder head chamber dependant. I have 1/2deg angle mill on mine to get down around 56cc, so I expected nothing over 34deg, but that motor just eats up the gas and timing and makes tons-o-power on the dyno. Good luck! |
Lo-Fi Version | Time is now: 26th June 2024 - 05:44 AM |
