Crane XR-700 install help, which shutter wheel, mount ? |
ArtechnikA |
Oct 19 2003, 08:44 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i'll save the rant on parts that don't fit for the after-project wrap-up.
meanwhile - for anyone who's installed the Crane XR-700 (715) points replacement module in an early six-cylinder Bosch dizzy - how'd you do it ? which shutter wheel, which mount, what did you have to fabricate to make it go ? my 'parts kit' came with two shutter wheels with 6 slits so it must be one of those... one has full notches, the other has holes - and a triangular/trochoidal center section that leads me to suspect it's actually for Mazda rotary... the notched one does fit the dizzy cam so i think that's what i need. except that when it's high enough to clear the screw holding the mounting arm to the breaker plate, it doesn't engage the cam - and it rubs the top LED. there's not much room to mount the LED/detector part much lower (to say nothing of no included parts to do it with...) so i'm wondering 'now what' ... meanwhile, i remain - sparkless in Philadelphia ... |
Neal |
Oct 20 2003, 10:14 AM
Member Group: Members Posts: 300 Joined: 23-April 03 From: Sammamish, Washington Member No.: 605 |
I have an XR-700 Crane in my 76 2.0, I used a Crane PS-61 Coil. I will look at my rotor for you tonight if you like, I can't recall. I do remember the rotor was a very tight fit and I had to really push hard on it to slide down the shaft. I am not a surgeon so I am sure you can do this if I can.
Lo-Fi Version | Time is now: 26th June 2024 - 06:23 AM |
