type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
on page 128 in the Haynes manual, Figure 9.21, there is a pic of the relay board with fuses numbered 9 and 10. 9 is a 15 amp fuse, 10 is a 30 amp. does anyone know which fuse, 9 or 10, corresponds to the fuse S13 in track 93 on the schematic on page 181? the schematic is for a 74 model.
the page numbers for different printings may be different from the ones in the question above but the figure 9.21 probably is the same figure (maybe different page number) and the 74 schematic probably is the same schematic another way to answer this question is to figure if the fuel pump would use a 15 or 30 amp fuse. thanks! |
type47 |
don't go away ... the reference to 9 and 10 are the haynes numbers identifying components for Figure 9.21, not the fuse box fuse numbers, for the 2 fuses on the relay board, thus there are no wires going to the fuses for color check.
yes, i'm trying to find out which fuse on the relay board is S13. the haynes figure 9.21 doesn't distinguish as far as i can tell. of the 2 fuses on the relay board, one of them is before (?) the fuel pump relay and is therefore, in the fuel pump circuit and i have yet to find what the other relay board fuse is for. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:02 PM |
