Crane XR-700 install help, which shutter wheel, mount ? |
ArtechnikA |
Oct 19 2003, 08:44 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i'll save the rant on parts that don't fit for the after-project wrap-up.
meanwhile - for anyone who's installed the Crane XR-700 (715) points replacement module in an early six-cylinder Bosch dizzy - how'd you do it ? which shutter wheel, which mount, what did you have to fabricate to make it go ? my 'parts kit' came with two shutter wheels with 6 slits so it must be one of those... one has full notches, the other has holes - and a triangular/trochoidal center section that leads me to suspect it's actually for Mazda rotary... the notched one does fit the dizzy cam so i think that's what i need. except that when it's high enough to clear the screw holding the mounting arm to the breaker plate, it doesn't engage the cam - and it rubs the top LED. there's not much room to mount the LED/detector part much lower (to say nothing of no included parts to do it with...) so i'm wondering 'now what' ... meanwhile, i remain - sparkless in Philadelphia ... |
ArtechnikA |
Oct 20 2003, 08:42 PM
QUOTE(scotty @ Oct 20 2003, 05:06 PM) These are the parts that I DIDN'T use. I hope this helps.... Hmmm.... that's the Z bracket i wasn't going to use, so i guess that's cool, but i couldn't get the other 6-slit shutter wheel over the points cam, i've been trying to use the one you didn't ... hmmm... i -think- my problem is how ive been trying to mount the Z-bracket to the dizzy plate, if my discussion with Crane tech support is any guidance... i'll check out the options... so - you used the shutter wheel with the 6 little windows - as opposed to the slotted one pictured here? interesting ... |
Lo-Fi Version | Time is now: 26th June 2024 - 06:14 AM |
