> Are roller bearings really that great?, anyone out there with some experience?
post Jun 23 2006, 01:54 PM
Resident German
are roller bearings really that great? (IMG:style_emoticons/default/idea.gif)
- anyone out there with some experience? preferably someone who did a install himself. and has driven some cars to compare.
- is the install really that hard?
- what about dirt getting into the bearings?
- change of effective springrate due to not fighting sticky rubber bushings anymore?
- got pics?
i still got my set (rears) in the box, they'll be going on the new trailing arms ...
(IMG:style_emoticons/default/smash.gif) Andy
J P Stein
post Jun 25 2006, 01:06 PM
Irrelevant old fart
Needle brgs *should* migrate around their cage thus presenting different rollers to the loaded (uppermost) areas....that coupled with the tight clearances of Mike's set-up
don't allow much "slop".
The polly bronze presents the same area to load constantly.....same as the plastic jobbies that wear oblong given a year or two...BTDT took pics.
oh.....them needles still ain't worth spit (IMG:style_emoticons/default/blink.gif)
brer
post Sep 1 2006, 09:24 AM
QUOTE(J P Stein @ Jun 25 2006, 12:06 PM) *
dont harleys use a needle bearing in the suspension pivot?
if what i've been told is correct, that bearing can wear notches in the race from the bearing 'not' migrating. Resulting in a washboard surface on the inside of the race. Once you get a wear groove started then the bearing definitely will not migrate. The small contact area of the needles could contribute to this no?
maybe?
definitely not?
SirAndy   Are roller bearings really that great?   Jun 23 2006, 01:54 PM
Mueller   they suck :D by the way, the rear have o-rings....   Jun 23 2006, 02:18 PM
kdfoust   I've got needle bearings in both front and rea...   Jun 23 2006, 02:27 PM
Brad Roberts   We are up to 4 years now with no grease needed or ...   Jun 23 2006, 03:32 PM
kdfoust
  Jun 24 2006, 12:57 AM
brp914
  Jun 24 2006, 11:17 AM
Bleyseng   I went with the poly/bronze as they are $100 ...   Jun 24 2006, 11:30 AM
Brad Roberts   ChrisC, Then why does Chuck use a picture of your...   Jun 25 2006, 11:14 AM
J P Stein   Needle brgs *should* migrate around their cage thu...   Jun 25 2006, 01:06 PM
brer
- Lo-Fi Version Time is now: 29th April 2025 - 08:55 PM
