Fiberglass and epoxy questions, Paul or anybody w/experience?, I've done research but there are varying answers... |
neo914-6 |
Sep 3 2006, 02:14 PM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
I'm working with TAP marine epoxy resin and various weights of mostly fiberglass cloth material. TAP is great but you have to find the experienced guy (like Home Depot or OSH) for good information.
I chose epoxy because it's odorless (CA neighbor friendly) and has good bonding strength. It requires more precise mixing ratios as I've found out the hard way. The questions Is the 914 top covered with a gelcoat? Does epoxy bond well to gelcoat? How long should you wait between laying the next layer of cloth? If more than 24 hours do you need to sand the surface for the next layer? Is there a water soluable layer you need to wash off or you may have delamination later? (IMG:style_emoticons/default/confused24.gif) |
alpha434 |
Sep 3 2006, 08:46 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Make sure you have a really good look at the whole spectrum of materials before getting in deep with C/F. It's EXPENSIVE. You may be able to get it down to just 2 layers, and then use foam board or something else to reifore it in just a few key areas.
Lo-Fi Version | Time is now: 25th June 2024 - 12:17 AM |
