Wasa914 |
Newbie ![]() Group: Members Posts: 13 Joined: 8-October 03 From: Ukiah,CA Member No.: 1,229 ![]() |
I'm a newbie to contribute but I have received a bunch of information from this board in the past which I am very grateful. Just wanted to share what I learned.
I am using a VDO electronic speedometer and have seen alot of innovative ways to send the electronic signal via the 901 trans. My solution is to cut off the slotted key end of the speedometer cable that fits the angled trans cable driver. Drilled out the cable hole and sodder in a shortened square key drive that is in the standard GM VDO sender. I had a machinist do this and make a bushing that will center the slotted cable end in the GM sender. The GM sender has a threaded nut that will fit the 901 angled cable driver which is amazing because I thought it wasn't meteric. Hopefully this picture will appear. (IMG:http://www.914world.com/bbs2/uploads/post-2-1066763782.jpg) Philip '73 914 still in transformation |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Is the signal for an electronic speedo sent via wire or some type of wireless comm?
If it's wire - what's the overall benefit for our cars? After all, we still have an ugly cable beneath, just waiting to be cut by debris, burnt by exhaust, etc. Curious, -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:27 PM |
