> When reinstalling a master cylinder, what do they mean?
Hammy
post Sep 11 2006, 04:20 PM
mr. Wonderful
I've been doing my searching on installing a new master cylinder and,
many seem to suggest completely taking out the feed lines and installing them into the master cylinder outside of the car. Seems simple enough, but, how are the feed lines reinserted back up to the reservoir? This is with the gas tank in.
bondo
post Sep 11 2006, 04:38 PM
Just disconnect the hoses from the reservoir, and pull them down about 6 inches. This allows you to get a good grip on them when pushing them into the master cylinder rubber grommets. The grommets go into the master cylinder, and then the lines go in the grommets. The sorta go "squick" when they they pop fully in place. Once they're in, put the master cylinder in place, then reconnect the lines at the top. Always use new grommets. Repalce the short rubber hoses at the reservoir (with the right type of hose) if they don't look new.
Hammy   When reinstalling a master cylinder   Sep 11 2006, 04:20 PM
jd74914   Why would you do that? I attached mine after I bol...   Sep 11 2006, 04:28 PM
Travis Neff   I have never tried this approach - but it seems th...   Sep 11 2006, 04:28 PM
bondo   Just disconnect the hoses from the reservoir, and ...   Sep 11 2006, 04:38 PM
Hammy   Thanks for the replies.
- Lo-Fi Version Time is now: 6th January 2025 - 04:37 PM
