bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
I liek the VW shifting, its more spacial than having a gated feel.
Is this what a tail shifter shifts like? If so I'd be intrested in backdating. |
dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
speaking of tail shifters, is the shifter itself the same as one from a side shifter? if not, is the coupler, the piece that connects to the shift rod with an adjusting screw the same?
bugsy0 |
Member ![]() ![]() Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None ![]() |
Also, with tail shifters it's critical to get the shifter adjusted right. When in second, the shift knob is practically _under_ the edge of the dash. If the shifter stick is too far backward, the "throw" is off and it will feel very vague. To adjust it, loosen the clamp under the tunnel cover near the fire wall and slide the shift rod forward/backward. Makes a huge difference.
Lo-Fi Version | Time is now: 21st June 2024 - 12:08 AM |
