> Rear swing arm mounting plate, Rusted and broke 1/2 the bolts
tracks914
post Sep 28 2006, 08:36 PM
Canadian Member
The 3 hole mounting plate on my project car (passenger side) is rusted pretty bad so I figured they have to come off for my resto so off they come. They seemed pretty rusted and tight so I soaked them from the top for about 2 weeks with penetrating oil.
Last night I went to take them off but I knew I was in trouble when they were spongy. WTF, grabbed the impact and got 3 bolts out OK and 3 broke off! (IMG:style_emoticons/default/headbang.gif)
Now this is going to be hard to get the broken bolts out. I might have to resort to drilling and re-tapping the holes unless some has a better idea?????Anyone ever have these seized in before??(a stupid question but....)
BTW I now need a passenger side mounting braket (plate) and shim!!
Tx
michel richard
post Sep 29 2006, 06:39 AM
That has happened to me too, several times. Those bolts are high grade steel and will dull regular high speed steel bits pretty quickly. So, get some cobalt bits, and try not to break them, because they're expensive, and drill away.
In some cases that I've done it, it proved not to be too hard. In others, it was frustrating. In all cases, I managed to do it and to put a bolt through with nuts on top as others have said.
Let us know how it goes !
tracks914   Rear swing arm mounting plate   Sep 28 2006, 08:36 PM
mihai914   Had it happen to one bolt on the previous car. It...   Sep 28 2006, 08:53 PM
tracks914   Mihai, did you once have an orange car that hit a ...   Sep 28 2006, 08:57 PM
mihai914   No, mine was Phoenix Red and a tree jumped in fron...   Sep 28 2006, 09:04 PM
JOHNMAN   I would recommend drilling it out and running a lo...   Sep 28 2006, 09:49 PM
davep   You will require cobalt drills to do the job, a re...   Sep 29 2006, 05:44 AM
michel richard   That has happened to me too, several times. Those...   Sep 29 2006, 06:39 AM
Racer Chris   I have gone so far as to use a hole saw to remove ...   Sep 29 2006, 07:17 AM
URY914   What about drilling it over sized installing a bol...   Sep 29 2006, 09:38 AM
tracks914   I'm going to wait until I get it up on the rot...   Sep 29 2006, 06:54 PM
URY914   I'm with Chris on using a bolt and a nut. I do...   Sep 29 2006, 07:11 PM
mihai914
- Lo-Fi Version Time is now: 29th April 2025 - 09:42 PM
