> Wiper Switch, How is it removed?
jnp914
post Oct 28 2003, 11:33 AM
I have problems with the wiper system on the '71.
-When the ignition power is on, I cannot get the wipers to move. In the full left position, I can wiggle the knob and I hear slight movement up around the motor, but I get nothing in either the middle (slow?) or right position.
-The Haynes manual says that I should pull out the knob to the first position for low and all the way out for high. Nope, the switch in the car is a rotary, three position. Which one is correct.
-How do I get the switch out of the dash? I removed the dash bottom, but see no obvious access to remove the switch.
TIA
post Oct 28 2003, 12:55 PM
Resident German
mine was rotary style too (before i switched to a late model harness) ...
removal is easy. first rotate the knob to the left, the top should unsrew!
then you see a metallic (alloy i think) ring with 2 slots in it.
now comes the tricky part. and i don't recall if there's still a stud sticking out once the knob is removed, but
IF NOT: just use a quarter (yes, money), it'll fit perfectly into the 2 slots and unscrew the metal ring. then the whole switch just slides out the back.
IF YES: you won't be able to get a quarter in there, so use a flat screw driver and carefullt pry counter clockwise. once the ring is off the whole switch just slides out the back.
Andy
- Lo-Fi Version Time is now: 6th January 2025 - 03:56 PM
