RS22b |
Type Broken! ![]() ![]() Group: Members Posts: 223 Joined: 8-January 05 From: Vernon, NJ Member No.: 3,425 ![]() |
OK, got basically everything lined up and ready to go, but before i start on this thing does anyone have any suggestions or tips on stuff to look out for and proper procedure on stuff?
what i need to know for sure is the procedure for bleeding these things bc they have 2 bleeder valves. THis is the first time in about 25 years that these things are getting replaced. I will be doing the front wheel bearings as well. Any help would be greatly appreciated. THanks, Billy |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Ignore the lower bleeders, unless the system has been drained of fluid or you have new/rebuilt caliper on there. If so, you can use them until you get fluid out of them, then only use the top bleeders. Remember, air rises, even through brake fluid--so you'll never get all the air out of the calipers using the bottom bleeders.
Uhh, not that I know that from personal experience or anything. (IMG:style_emoticons/default/rolleyes.gif) --DD |
Lo-Fi Version | Time is now: 27th June 2024 - 09:08 PM |
