Mystery Calipers, "M" strut mounts |
914Sixer |
Oct 7 2006, 09:14 PM
914 Guru Group: Members Posts: 9,005 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have been working with Eric Shea to try and guess where thes calipers came from. I got them in a parts car. The guy said he took them off of a 911 with "M" struts. I bolted the calipers up with no problems and they clear my 8" Fuchs. I have included some pictures with compairsion. The caliper pistons are hollow. Eric says BMW or MB.
I measured the openings on the caliper for compairison: Mystery Caliper "M" Caliper 58 mm 54mm Width 77mm 62mm Length 25mm 24mm Rotor opening Attached image(s) |
Eric_Shea |
Oct 8 2006, 10:43 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
With the input "peak" and the mount to one side... I'm going to fall back on my Mercedes/BMW caliper. These are virtually identical to A-Calipers with the following exceptions:
A-Calipers are (obviously) on a 3.5" spacing A-Calipers have the input at the bottom of the peak. The larger Mercedes sedans went vented and I believe they remained on 3" spacing. I have done a set of Mercedes calipers that were "very" similar to these. I need to check the mounting spacing. BMW's could have been the same way but I don't know enough about the mark to give an opinion. It would be great to know what they are. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:30 PM |
