nine14cats |
Bill Pickering -- 914-6 GT aka....Leeloo ![]() ![]() ![]() ![]() Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None ![]() |
People have been asking to see pics of BPR's latest addition. Here are a few pics of our soon to be track only Boxster. Call it a Spec Boxster "Plus".....we can never leave well enough alone.
In a few weeks we will show you what a highly motivated and skilled crew can do to such a pretty car in one weekend. A build crew made up of (6) 914Club members are part of the build crew. In the span of (2) days we plan to: Install PSS9's Install Tarett Fr and Rr adjustable swaybars Install EPIQ front camber plates Install drilled rotors Fr and Rr Install Pagid Orange pads Fr and Rr Install B&M short shifter Flush brakes with Pentosin High Temp brake fluid Replace stock muffler with gutted racing muffler from Sportech Remove soft top, soft top motor and soft top transmissions Gut interior Remove dash for TonyC to put in custom cage Randal and I will be taking the car out for a AX shakedown at the last GGR event on October 28th. The plan is to have the cage, seats and harnesses installed to test at Sears on November 12th. Doris will be the primary pilot next year in the GGR Time Trial series. Randal and I will also be driving the car as well. We will document the car build realtime....the countdown has begun.... October 21st/22nd....tick...tick...tick...tick... Bill P. Attached image(s) ![]() |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
QUOTE I have a HALON in car system for the Boxster. NICE!!! I'll need the nozzles out of the kit along with the tubing. BEFORE cage it needs to be "somewhat" installed. One nozzle on the drive One on the passenger area One on the gas tank area/battery area One or two on the fuel rails in the engine compartment. Is this a system that you can arm/disarm for testing? If it is electric, we will mount the button on the plastic cowl section under the windshield. If it is the cable style, we will need a crimping tool for the "aluminum" cable crimps and some bicycle cable if it didnt come with extra. B |
nine14cats |
QUOTE I have a HALON in car system for the Boxster. NICE!!! I'll need the nozzles out of the kit along with the tubing. BEFORE cage it needs to be "somewhat" installed. One nozzle on the drive One on the passenger area One on the gas tank area/battery area One or two on the fuel rails in the engine compartment. Is this a system that you can arm/disarm for testing? If it is electric, we will mount the button on the plastic cowl section under the windshield. If it is the cable style, we will need a crimping tool for the "aluminum" cable crimps and some bicycle cable if it didnt come with extra. B This was/is the 3 nozzle manual system that was going in The Beast. I also have a new fire extinguisher. We can decide what to do when you get here. Thanks, Bill P. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:14 PM |
