> Need help starting
Hammy
post Oct 19 2006, 09:19 AM
mr. Wonderful
I'm wondering where to start here.
I have a 1.7 with dual Webers that I need to get going (parents on my ass (IMG:style_emoticons/default/smile.gif) )
My initial thought is to just get it running "okay" enough to drive it down to a shop and have it fully tuned up.
Or I may just take the plunge and attempt it all myself (I'm thinking this is a bad idea)
What would the first step be?
The engine has hydraulic lifters. Does this mean I don't need to touch the valves?
The timing. Is this something a total 'newb' should attempt themself? I've been reading up on how to set the timing and it seems pretty simple. I've been thinking of getting a timing light.
As far as adjusting the carbs, I have no idea where to start.
As of now, the engine will turn over and sputter and seem like it wants to start, and occassionally will fire up for a split second but die off again.
Where do I start with the carbs? Any "how to" articles out there?
Where do I start in general?
I could really use some assistance here.
TIA - Zack
toon1
post Oct 19 2006, 09:42 AM
If it sputters and kicks, sounds like you're close. A timing light will be good to have for future use, there cheap to buy.
I'm in Tracy and may be able to lend a hand
Check the search for info on carbs. Good luck
Hammy   Need help starting   Oct 19 2006, 09:19 AM
toon1   If it sputters and kicks, sounds like you're c...   Oct 19 2006, 09:42 AM
SGB   Junk in the carbs is a likely culprit. I have hy...   Oct 19 2006, 01:36 PM
SGB
- Lo-Fi Version Time is now: 12th November 2024 - 04:21 PM
