Need to know |
Need to know |
StratPlayer |
Oct 28 2006, 05:01 PM
StratPlayer Group: Members Posts: 3,300 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
What is the function of the this threaded hole on the crankcase?
Attached image(s) |
StratPlayer |
Oct 29 2006, 01:23 PM
That picture isn't very clear, the piston and spring that would go into there would have to be small. Are these parts available for this setup? I have some pistons that do fit in that hole, I also have some springs that are smaller then the piston relief in the front of the case. I'll have to see if they fit, they probably are the parts I need to set this up. Mark in that pic does the piston have a slot in it?
This is what I have, looks like the smaller spring that I have is to wide, won't fit in that hole. The top part of the picture is the setup for the front, the bottom, I think is the setup for the back section of the case not sure, if it is then all I need is to find the spring that goes into that hole. Attached image(s) |
Lo-Fi Version | Time is now: 6th January 2025 - 08:31 PM |
