6 vs 4 |
6 vs 4 |
914fan |
Oct 31 2006, 11:20 AM
Member Group: Members Posts: 118 Joined: 17-January 05 From: Fountain Valley CA Member No.: 3,460 |
How do a 200hp 6 and a 200hp 4 drive compared to eachother. I know there are several ways to get 200hp out or either. I am interested in a daily driver 200hp 6 or 4. Does anybody have any dyno charts of these? Is the 6 more peaky? is the 4 more torquE? Type IV and Porsche 6 please.
I am not trying to start a flame war. I am just looking for information cause I found an empty spot in my brain, and I need to fill it before something else goes in there. |
Trekkor |
Nov 3 2006, 02:24 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
QUOTE There is no altered cooling system needed, no ALTERED MOUNTS, NO GRINDING, NO WELDING or any of the things that would be considered "conversion".... I think Grant was referring to the need for aftermarket intake, exhaust, dizzy, fuel delivery and additional cooling if you want it to last *ONE* 30 minute DE session in the summer. If it doesn't plug'n'play, it's a conversion in my mind (IMG:style_emoticons/default/confused24.gif) KT |
Jake Raby |
Nov 3 2006, 03:09 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE There is no altered cooling system needed, no ALTERED MOUNTS, NO GRINDING, NO WELDING or any of the things that would be considered "conversion".... I think Grant was referring to the need for aftermarket intake, exhaust, dizzy, fuel delivery and additional cooling if you want it to last *ONE* 30 minute DE session in the summer. If it doesn't plug'n'play, it's a conversion in my mind (IMG:style_emoticons/default/confused24.gif) KT Then you are confused.. Its not a conversion and YOU DO NOT NEED BETTER ENGINE COOLING THAN STOCK for todays 200 HP/4... OIL COOLING is not engine cooling, most STOCK -4 engines need an external oil cooler for a D/E event in the middle of the summer.. None of that is considered a conversion, they are UPDATES... You guys that have never done this don't understand the fact that one of these engines can be installed in one weekend by ONE PERSON including the oil system... I have done it many times by myself.. The factory pressure plate will hold 200HP, all you need is a 85 dollar clutch disc- thats not a conversion unless you weld the pressure plate on! The Mallory unilite drops in and installs in 1/2 hours, is that a conversion- nope, nit unless you are totally lost and have no clue as to what a 13mm wrench looks like.. Its very obvious that you guys are totally lost on the subject of what it really takes to install one of these engines, if you call the reinstall of an engine thats only had its displacement increased a "concversion" you need to do some more research.. So I guess if you have a 3.0 six and you pull it out and make it a 3.2 its a "conversion"?? By your standards it is.. Bullshit. Anyone who wants to hear a testimonial from a 914 club member that has a 202 HP 2316 in his 914 can download this radio show from my archives 4th Dimension Radio To me a six cylinder engine just means it has two more rod bearings to wear, 4 more rod bolts to break and 4 more valves to drop.. More parts = more chances for mechanical failure... Its all about doing more with LESS! Oh yeah, where is that six cylinder that doubles its HP with 15% displacement gain... better yet where is the 2.4L six that can top this power on PUMP GAS N/A (IMG:http://www.aircooledtechnology.com/mightyspyder_dyno.jpg) |
Lo-Fi Version | Time is now: 10th November 2024 - 12:27 PM |
