> Megasquirt Mappings, for 1.7L engine
bd1308
post Nov 14 2006, 06:23 PM
Sir Post-a-lot
I need this thing to have some baselines pretty quickly. Basically I really need this thing to be like a weekend project in order for me to get to work/school on a monday or something.
at least something is needed to get it to idle, I plan on using a WBo2 sensor to aid megatune to tune my engine, I also plan on first using 'fuel-only' function in MS for now, and then add spark using the hall effect system(or optical?) that VW actually employed for the vanagons.
any help would be appreicated, i'm still in building phases( collecting needed small parts, etc.) but would like some gameplan.
Is it easy enough to add spark after the unit is programmed?
mightyohm
post Nov 14 2006, 08:38 PM
I just posted all my MS settings in toon1's post about a week ago. Those settings should get the basically running if nothing else, as long as you wire the sensors in a similar way and use an MSII (or you can use the settings to create a map for an MSI manually, there might also be software to help with that).
I don't recommend putting the MS box into a stock ECU box. It is a bad idea for several reasons including:
1. it gets too hot in the engine compartment
2. environmental exposure, esp moisture
3. hard to access for repairs, tweaks, and firmware reflash
4. you will need to find a place for your wideband controller anyway, put the MS nearby along with the fuses and injector resistors.
bd1308   Megasquirt Mappings   Nov 14 2006, 06:23 PM
DNHunt   Britt Set up the general settings like the # of c...   Nov 14 2006, 07:03 PM
mikez   I found a wide band 02 sensor is the best sensor a...   Nov 14 2006, 07:27 PM
bd1308   what about connectors? I was thinking about going ...   Nov 14 2006, 07:55 PM
mikez   Why would you change connectors unless they are ba...   Nov 14 2006, 08:12 PM
jkeyzer   I just posted all my MS settings in toon1's po...   Nov 14 2006, 08:38 PM
bd1308   I see. Well I guess DB-25 it is. I plan on making...   Nov 14 2006, 09:00 PM
rick 918-S   WTG! Britt! Learn how to get that thing wo...   Nov 14 2006, 10:22 PM
bd1308   Yeah...when I ask questions though, people like to...   Nov 15 2006, 01:08 AM
bd1308   OK, im out. I have two packages to send, and then...   Nov 15 2006, 01:21 AM
Bleyseng   :WTF: is "Happyland"???   Nov 15 2006, 10:26 AM
rick 918-S   Dude! I met this kid. He's very bright. Yo...   Nov 15 2006, 10:58 AM
jkeyzer   The DB-25 connector on the MS is definitely the we...   Nov 15 2006, 11:15 AM
trekkor   Brit, i apologize. ( jabs deleted ) I saw your po...   Nov 15 2006, 11:31 AM
rick 918-S
- Lo-Fi Version Time is now: 31st October 2024 - 08:25 PM
