> Easy Alternator test?
ChrisReale
post Nov 16 2006, 04:42 PM
Sleazy
Is there an easy multi-meter test you can do to see if the alternator has crapped out? I guess the fact that my battery doesn't charge is proof enough, but I just wanna make sure.
McMark
post Nov 16 2006, 10:08 PM
914 Freak!
Nope, if the bulb is burned out the alternator will not excite and will not charge.
Jim, that's wrong. If the bulb is burned out the alternator will do NOTHING. The electricity created by the alternator does not run through the bulb. Once the alternator is excited, you can take the bulb out and it will keep on charging. But the alternator needs that little kick start to start making power. There's a ton of articles about alternators on the web if you want a clearer understanding.
ChrisReale   Easy Alternator test?   Nov 16 2006, 04:42 PM
So.Cal.914   When your car is running put the probes on the pos...   Nov 16 2006, 04:52 PM
Rand   Also check your voltage regulator before replacing...   Nov 16 2006, 04:58 PM
Michael N   Also check your voltage regulator before replacin...   Jan 9 2015, 12:11 AM
vsg914   I assume you checked the belt first?   Nov 16 2006, 05:15 PM
Scott-thundercat   check the battery voltage before it's started ...   Nov 16 2006, 05:44 PM
McMark   As mentioned, the voltage regulator can be bad as ...   Nov 16 2006, 05:59 PM
Brew
  Nov 16 2006, 07:41 PM
McMark   Nope, if the bulb is burned out the alternator wil...   Nov 16 2006, 10:08 PM
SGB   Absolutely true. As McMark says, But it RARElY b...   Nov 16 2006, 10:25 PM
Spoke   To check the alternator assuming that the belt is ...   Nov 17 2006, 09:31 AM
cary   Revive an old thread .............. Just trailered...   Jan 8 2015, 11:45 PM
cary   Did that cause the alternator light not to fire up...   Jan 9 2015, 12:15 AM
Dave_Darling   Yes, when the VR is not plugged in, the alternator...   Jan 9 2015, 11:18 AM
cary   Yes, when the VR is not plugged in, the alternato...   Jan 9 2015, 12:30 PM
type47   I'd like to listen to a discussion on how the ...   Jan 9 2015, 11:44 AM
Dave_Darling   I'd like to listen to a discussion on how the...   Jan 9 2015, 02:35 PM
mikesmith   I believe the alt light runs off of the alternato...   Jan 10 2015, 12:54 PM
cary   Back in business. The new Beru VR positions furth...   Jan 9 2015, 09:13 PM
rhodyguy   Happy motoring!   Jan 10 2015, 10:35 AM
jdlmodelt   Okay, alternator wasn't charging. I put 12.5Vd...   Jan 3 2020, 04:14 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 14th January 2025 - 06:50 PM
