Easy Alternator test? |
ChrisReale |
Nov 16 2006, 04:42 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Is there an easy multi-meter test you can do to see if the alternator has crapped out? I guess the fact that my battery doesn't charge is proof enough, but I just wanna make sure.
Spoke |
Nov 17 2006, 09:31 AM
Jerry Group: Members Posts: 7,116 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
To check the alternator assuming that the belt is ok and everything is mechanically sound, do a test which simulates the voltage regulator applying voltage to the armature to increase alternator voltage.
Sorry, I don't have access to my schematic. (It's at home and I'm in South Korea) So my instruction will lack the actual wire designation. I did this test to separate voltage regulator issues from alternator issues. My low voltage issue was the voltage regulator. Look at the schematic for the voltage regulator (VR). The top most connection from the alternator provides power to the VR and senses alternator voltage. The center lead in the schematic is the armature positive lead and inside the VR, this lead is connected to what looks like the contacts of a relay. The VR connects this lead to the alternator voltage to increase the voltage and opens the lead if the voltage is sufficient. If you connect the armature positive lead to the top most connection from the alternator, you will simulate the VR trying to increase alternator voltage. Connect the leads together first then start the engine. If the alternator is ok, the battery voltage should rise to about 15-16 volts. If it doesn't, you either have done this test incorrectly or your alternator is bad. If you are unsure about the VR connections, do not do this test. Spoke |
Lo-Fi Version | Time is now: 14th January 2025 - 06:19 PM |
