auxillary heating fan wiring question, and the cockpit switch for the heater |
brant |
Nov 21 2006, 12:17 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Hey gang...
is my memory on this correct? does the heather lever/fan switch only have one electrical wire to it? is that a ground wire or a current flowing wire? (it must be hot since its identified in the current diagrams) I'm trying to trouble shoot why my auxillary heater doesn't work and want to understand how that switch works. when the switch is open/on.. does it send power to the engine compartment and regulator board? how does the switch work if it is only a single wire? or does it then send a ground signal to the back instead? thanks for everyone's time brant |
TravisNeff |
Nov 21 2006, 12:46 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I definately think that is wrong. Eliminate the fan lever switch and do the same check on the wire in the cockpit (removed from the lever). That can at least rule that portion out.
Lo-Fi Version | Time is now: 19th June 2024 - 01:40 PM |
