Tunnel vision - Clutch tube that is |
JeffBowlsby |
Nov 25 2006, 09:25 AM
914 Wiring Harnesses Group: Members Posts: 8,562 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached image(s) |
Rand |
Nov 26 2006, 01:32 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
So, the tricky part is: Drilling without damaging the tube. And putting something inside the tube before welding to make sure the weld doesn't penetrate the tube. Right?
So... What about doing the repair without removing the clutch cable? I'm thinking preventative here. Maybe cut a piece of copper tubing that fits snugly inside the clutch tube... slot it lengthwise enough to get it over the cable and slide into the clutch tube, rotated so slot is opposite of weld.... Pull it back out after welding. ??? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:28 PM |
