jsteele22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 ![]() |
So I've been working on my RH hell hole area as time, weather, and motivation allow. Using a wire wheel wasn't cutting it, so I got some blue (AlO2) gringing wheels for the electric drill. In the affected areas, I seem to cut through (in order) : colored paint, black layer, powdery rust, shiny metal.
Q1) The black layer is very tough, and doesn't seem to appear in areas where no rust occurred. Could this be some PO's rust converter job ? There is definitly some rust under the black stuff. The rust situation is not bad in general. Apart from the battery tray, which I removed, there are no rusted through areas. But I've been a little worried about how strong the remaining metal is after pitting due to rust and then my grinding. Then, down in the very worst part of hell, not far from the "drain" hole, I found a tiny (1/16") spot that looked like a hole. I went at it pretty agressively with a blunt grinding wheel and found this : ![]() My first thought was that the rust had started to penetrate outwards from a deep pit and form a large flake. So I went at it with a screwdriver, and started prying up the top layer. Here's what I found. (Although the rust-colored dust really stands out in the flash picture, in real life everything looks quite a bit cleaner.) : ![]() And here's where it's located : ![]() In the close-up, you can see smooth, grey primer surfaces between the two layers. In real life, the bottom layer looks clean and rust free (apart from the rust powder.) Q2) What is going on here ? Are there really supposed to be two layers of metal ? How far does the 2-layer portion extend ? ( It doesn't look like a repair job to me, but ya never know...) Q3) Although there aren't any more rusted-through holes, the metal in the deeply pitted zone is pretty flimsy, or at least it will be when I grind the rust off (like the part I pulled up with a screwdriver). What should I do : small patch just to seal the hole ? Cut out "top" layer of pitted metal and replace it ? Leave pitted layer in place and patch over it ? Bondo and sell to Ferg ? |
highways |
Senior Member ![]() ![]() ![]() Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 ![]() |
So as long as the second layer of metal doesn't have any rust, I'm okay structurally ? The top layer only has that one hole in it, but overall a lot of material has been removed by rust and by grinding. Dude.. it only has that whole because you made that hole! No but it's fine, you just went exploring and had to convince youself. The long is a box and I think there are two layers of metal there. You poked through some thinner sheetmetal on the top- not so structural. The next layer is a little thicker. Ultimately you will want to seal that exploring hole back up so that no water can ever work it's way in there. For that I would spray the Zerorust paint in there wet so it runs in as much as possible sealing up the edges. Then you might want to throw a good quality bondo patch to plug it even further. You've got plenty of metal everywhere. You're structure is not compromised in the least even if there were a few small holes. You just want to preserve it for the future even if it's slightly thinner from gentle wirebrushing (you should not be grinding- you're metal is too good so don't grind it away) The goal is to not have any intrusions which will allow water to enter the inside of the long and begin the rusting from the inside out. When you go exploring with a screwdriver... bad rusted areas should flake off with ease- as if it was a rotten log of wood. If it is a bit tougher- like a healthy log of wood you don't need to worry or force anything. You are only looking for crumbling swiss cheese- which is usually evident by holes that are already present. If it doesn't crumble or look like it would let water in- then you have been blessed by the 914 gods. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:15 AM |
