Mid_Engine_914 |
Member ![]() ![]() Group: Members Posts: 195 Joined: 22-September 06 From: Left Coast Member No.: 6,888 ![]() |
one has the 914/6 suspension and brakes and one has the 914/4 suspension and brakes. Also assume both cars have anti-roll bars and 180hp engines. What’s the difference in how they perform on the track?
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
I take it you mean both have the same engine correct? Just the suspension is different??
as is, the /6 suspension should have slightly stiffer torsion bars and slightly stiffer rear springs if one used bone stock factory parts.... as for brakes, the /6 front rotors are vented, but that might not come into play depending on the driver or course... I would almost have to say that as long as you have no issues with heating up of the front brakes, there will not be a measurable differance... |
Lo-Fi Version | Time is now: 25th June 2024 - 01:13 AM |
