Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Second-hand, never-used (IMG:style_emoticons/default/piratenanner.gif)
I may weld it in and go to the dark side over the winter... KT |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
REMOVE your front targa latches. You dont need them after the cage is installed.
Then.. removing the top becomes a NON issue. I suggest removing the rear targa pad also prior to install. This will give you move access to the rear latches. B |
Lo-Fi Version | Time is now: 21st June 2024 - 12:02 AM |
