Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Second-hand, never-used (IMG:style_emoticons/default/piratenanner.gif)
I may weld it in and go to the dark side over the winter... KT |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
mounting plates need to be thick and big. read the (SCCA) gcr for necessary dimensions (I forget off top of my head, but probably .120 thickness -- there is also a surface area requirement iirc). i think mine were 3/16" thick. jp's pictures look just right to me, and andy's cage is obviously worth checking out in person. I think you are definitely going to want to weld this thing in.
have you determined if the tubing is dom? what's the OD and wall thickness? just curious -- i think this setup will be just fine for your intended purpose. i might have some extra dom 1.5x095 in the garage that i could sell you undermarket if you need to do any additional fabbing. |
Lo-Fi Version | Time is now: 21st June 2024 - 12:02 AM |
