I bought my roll cage today, Autopower bolt-in |
Trekkor |
Dec 7 2006, 11:29 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Second-hand, never-used (IMG:style_emoticons/default/piratenanner.gif)
I may weld it in and go to the dark side over the winter... KT |
Trekkor |
Dec 9 2006, 02:43 PM
The Engman kit is under an 1/8" thick.
The base of my cage for bolt-in installs is 3/16" thick. 2 1/2"x 5" bolt plates. I want to weld these to the top of the longs. Also use a matching plate under the car that I can bolt through and weld to the underside. The tube is 1 3/4" OD and 1/8" wall thickness ( .125" ) Nate, I would like to get that tube. How long of a piece( s ) do you have? Randal, do you have some pics of the knee bar? KT |
Randal |
Dec 10 2006, 02:52 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
The Engman kit is under an 1/8" thick. The base of my cage for bolt-in installs is 3/16" thick. 2 1/2"x 5" bolt plates. I want to weld these to the top of the longs. Also use a matching plate under the car that I can bolt through and weld to the underside. The tube is 1 3/4" OD and 1/8" wall thickness ( .125" ) Nate, I would like to get that tube. How long of a piece( s ) do you have? Randal, do you have some pics of the knee bar? KT The cage was put in when the car was stock. As I've said I've never hit the dash bar. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:48 PM |
