Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Okay... I cleaned up the steering rack of years of goop and grime. I'd like to relube the inside of the rack. Has anyone done this?
What type of grease??? I know it's not good to mix different type of greases. I imagine I should just add additional grease, rather than try and clean out what's inside with some sort of chemical. I'd hate to screw up some rubber o-rings or gaskets inside. I think there is a spring on the backside of one of these plates... Any pointers???? Thanks! Attached image(s) ![]() |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Karl, I did the rack rebuild a few years ago on my 911. I totally disassembled the unit, cleaned it all up.
That plate unbolts, then there is a spring and some sort of shim that bears against the rack, after you remove the plate/spring/shim you can remove the rack and clean it all up. I dont remember and rubber o-rings though. I put it all back together using some nasty dinosaur shit moly grease to lube it. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:58 AM |
